Thanks, I ran the drain into a small fuel filter that the tube fit in, I plugged the other side. It should do the trick. In any case it will be interesting to see how long it takes to fill. The bottom right bolt hole didn't appear to be open as using a thin wire, I was only able to insert it about 3/4 inch. It looks like even if I could find the right fitting it wouldn't drain anyway.
BTW, Joe came through for me with the hose for the 72, and shipped it supper fast! Thanks Joe.
