Re: pulling lower unit off yamaha
You will probably only need a new impeller and possibly some of the miscellaneous parts which go on the shaft above the pump on the shaft, my 200 has a little stainless sleeve over he shaft on the top of the pump, which apparently seals the top of the pump. take the pump body with you to the parts house and have them look at it and make sure it is in good shape, when you put the lower unit back on, a strap such as a motorcycle strap can save you a lot of strain and pain as you raise it in position, be sure to verify that the shift shaft lines up and makes a connection with the socket on the upper portion of the shift shaft,, Good Luck
