Proper Trim Tab Size???????
tank1949
I found out the other day that my trim system is woefully too small. I have hyd. 12x9 tabs on a 29 ft Proline. Bennett recommends 18x12 with down fins on the side due to the limited stern area available to add larger tabs. Bennett doesn't make trim planes with larger than 12" chords. However, for those of us who have heavy dual I/Os with limited trim span areas, perhaps a 14" chord might be even better. I can get larger ones (18x14) made at local fab shop, but Bennetts have always been the chosen trim makers. Any suggestions???????.
alldodge
Re: Proper Trim Tab Size???????
I have about 12 or 14 inch wide by about 10 long on my Formula 27PC (28.2 long x 9.5 wide) and drafts 42 inches. Bennet says I should have 30 x something. I would measure the tabs but the boat is in the water and will be a few more days before I get back to it. They do very well and have no issues and my boat weights 9500 dry so I guess I'm coming in around 10500. Looking up your boat it comes in at 5000 dry.
Pro-Line 29 Super Sport | Salt Water Sportsman
What kind of power do you have?
Tabman
iboats.com Partner
Do you have a photo of the boat's transom you can post?
Jdeagro
iboats.com Partner
Hi Tom!
Are you Back? Hope So!
Tabman
iboats.com Partner
Yup, I'm back! Got out of the hospital on Friday and feeling pretty good! Slowly coming back to speed on the forums.
The surface area of the Trim Tabs are a really important factor in the amount of lift they generate. Surface area, speed of the water flow, and angle of deflection are the three main factors.
A photo would help us see what will best fit your transom.
