daveywonder
- Feb 21, 2012
- 38
After getting motor ready for water, [only with the help from this forum], the tilt and trim works, but the previous owner has the trim set at the futherest-out hole position with a good size bolt on each side. My previous manual trims for other boats has always been set ,[ 2nd from the inner-most setting ].... For the first time out, where should I have the trim set at when the tilt is all the way down??? 17 ft. Newman tri-hull 120 force Appreciate any advice..tks,,,DAVEYWONDER
