steelespike
- Apr 26, 2002
- 19,069
If the 22 gave you 4800; a 23" would usually lower rpm about 200 and top speed probably would be about the same as the 22" prop with slower hole shot.
Comparing the 4 blade 21 to the 22 would likely be slower.Hole shot should improve along with the other improvements i have suggested for a 4 blade.
I think you should forget about a prop until you get the bottom smoothed out and measured to see if there is a hook.
For now I would stick with the 22.
