There have been several threads around unpowered Quabbin boats, so I thought getting another data point out there might help someone. Today, I had a chance to test two props on my Lund.
Background: the boat is a 2004 16' Alaskan tiller, with a 25 Merc bigfoot. It was loaded with me (185 lbs), a half tank of fuel ~10 gal, 2 batteries, bow mounted TM, and misc supplies and gear (unknown weight).
First prop was a new 4 blade 12 x 9 alum. With this prop, I saw 17 knots, but only 5100 RPM's. I tried this several times on different tilt settings, and this was the best performance.
Then I switched to a 10.88 x 11 alum 3 blade prop. I got basically full RPM's (~5650) and saw 19.4 knots with the same tilt setting that worked best with the other prop. I did not test other tilt settings with this prop. In the past this prop has produced 20 knots and change for me--but the load could have been much less.
I was really surprised that the extra inch of diameter and the 4th blade would not gain RPM's despite having 2" less pitch.
Initially, the hope was that the 12x9 prop would help run the boat better with additional people aboard, but it does not look like this is a better real world solution than is my existing 10.88x11. I did notice that the 12x9 FELT like the boat was not as deep in the water, and it may have been marginally faster to plane, but I did not time it.
Last weekend, I had the boat on the CT river, and with one other guy (~180 lbs) and similar gear, was going upstream at about 12 and downstream at about 15.5. It was very windy, and the downstream run was right into it. Given the strong currents this would extrapolate around 14 knots, which is a knot and a half LOWER than what I have seen with the 10.88x11.
Next step is to see if I can exchange the 12x9 for either a 12x8 4 blade or for a 9 pitch 3 blade model. Any advice as to which might be a better choice?
Thanks
Thanks
