imported_Samuel
- Jul 6, 2006
- 60
Hello-
I have a 40HP Lark VI (1964). I am looking into prop. issues, such as replacements etcetera. This motor has a pin drive, with a ¾ inch shaft, no splines (except the 2 positioning cut in on wall).
OEM prop has a base height of 3 inches. So as I look, I find many great used props., pin drives, but with a 7/8 hole. They appear to fit in all other specs., but would be loose if installed. Thus the question(s) below:
If I find a prop. That is a slightly larger diameter, say 7/8, can I shim the prop. , making sure it is concentrically centered?
Will the shims increase damage potential? if so, why?
Yes, I can find new props to fit, but they are aluminum or Very Very expensive if S/S. I need a SS prop. due to the fact that the lake I run in has a sandy, silt bottom with lots of shallows and hidden treasures
Not trying to be cheap. But necessity (and a not too fat checkbook) is /are the mother(s) of invention.
Related Q:? Can I use washers or pipe (use as a sleeve) with washers at each end as a base extension should the prop. be less than the 3 inches the original is?
Many Thx.
Sam
Many Thx.
Sam
