Groupergulper
- Aug 21, 2009
- 73
1993 Robalo 2120 , 21' center console, T-Top, trim tabs 1999 Yamaha 225 OX66 Saltwater Series
AS TESTED:
3600 dry weight, Yamaha weighs like (550), 100 gallons of Gas (630) Coolers, gear, ect. (400), 3 people (550), Total: 5730
Motor trimmed to the same position for each prop, trim tabs in same position
1999 Yamaha 225 OX66 = Operating Range per manual is 4500-5500
Mph is from gps
First prop, Not sure of brand, Stainless steel in like new condition, ( made my lower unit noisy at idle and low rpm )
14.5x19 5000 WOT
5000 = 41 MPH
4000 = 29 MPH
3500 = 21 MPH
Second Prop, Solas Amita 3, Aluminum in like new condition
15.3x19 4800 WOT
4800 = 41 MPH
4000 = 34 MPH
3500 = 27 MPH
My goal is to get the best fuel economy/performance I can, the fuel economy doesn't seem that good, after testing the props yesterday we went fishing, I left the 15.3x19 prop on and continued for a total of 52 miles round trip, the mpg was 1.8, I cruise normally between 3400-4000 depending on seas. The 15.3x19 seems like its a good fit for my boat but i wonder if there is a better fit?
I dont see much discussion about prop diameters, mostly pitch. I would think for a heavy boat you would want more diameter or at least more blade surface area.
I dont fully understand the operating range? Who runs wide open all the time? Is operating range peak HP? Has to be sucking fuel at that rpm. Am I missing something here?
Is it odd that both props had the same max MPH at different WOT?
AS TESTED:
Mph is from gps
14.5x19 5000 WOT
5000 = 41 MPH
4000 = 29 MPH
3500 = 21 MPH
15.3x19 4800 WOT
4800 = 41 MPH
4000 = 34 MPH
3500 = 27 MPH
