Coast Ranger
- Aug 8, 2011
- 21
I have a 28' AquaPatio pontoon boat with a 70 hp Mercury on it. The prop is a 3 blade, 13 pitch. The motor seems to be running good, with a couple of boat people agreeing to that. Periodically, I'll have a problem where the prop seems like it's not "biting" the water properly. Yesterday, we ran with the current a couple of miles to our favorite spot. The motor was turning at 3800 rmp which pushes at a comfortable speed - not fast but not slow. On the way back, against the current, the boat felt like it would loose power. There was no difference in the sound of the motor, like would accommodate a loss in propulsion. Throttling up did not help. We were up to 4500 rpm and it still felt like the boat wasn't moving like it should. Throttling down to 1500 to 2000 rpm produced the desired forward momentum - what you would expect for that level of throttle. When the "problem" is happening, I can look behind the boat and still see a lot of water being pushed behind the boat. Lastly, I don't feel any undue vibration.
I've tried every practical trim without result. Could I be churning air into the water under some conditions that decrease the bite? Maybe the prop is not far enough in the water? Maybe mounting it lower on the transom or (heaven forbid) a motor with a longer mid-section? Would I benefit from a 4 blade prop? I'm not interested in speed, but I do want the boat to move accordingly as I throttle up.
Thanks in advance for any ideas or suggestions,
CR
Mr. Moderator, If this would be better suited in the Props forum, please move it there for me. Thanks, CR
CR
