Puncheon50
- Jan 4, 2017
- 48
After all I have been through getting this 70hp Johnson going strong, I am embarrassed to ask this question but I am anyway. I bought a new Turning Point prop for it and got the kit. So the old prop had the nylon nut with spline fitting. The new nut is pretty much a punched flat washer, no spline slots. I am leary of using the steel. Should I just reuse the nylon? Also, as far as torquing the castle nut. I saw on here 12ft Lbs for nylon nut and 70ft lbs for steel. Is that correct?
