Does the prop move on the shaft?<br /><br />Does the prop and shaft, move as one, in/out of the gearcase?it's slight front to back movment on the shaft.
Compare the origional prop and thrush washer to the new prop and new thrush washer. May require precise measuring with calipers and depth guage.<br /><br />Contact a local prop shop, or the place you acquired the new prop.thanks, is there a way to tell if the proper thrust washer is in place?
