Re: Prop for 16' kingfisher with 70hp johnson
I guess you have a fiberglass bass boat. If that is the case, my boat is very close to your boat. Johnson recommended to use a 13"1/4 x 17" prop for 85HP engine on an average load. When I used a prop of that size, the boat performance was not good. I ended up using a Michigan Wheel 13"X19" 3-blade prop. So, you can look at the props in this neighborhood.
