bigrockets
- Jul 12, 2010
- 63
I have a 17 ft center console boat with a 50 evinrude 1990. I recently purchased the boat. The previous owner used it for some fishing and mostly pulling tubes with 3 to 4 people. I intend to use it for fishing and some cruising with 2 or 3 people. I test drove it for the first time this past week. It gets on plane slowly and seems to over rev at WOT. The engine spec is WOT between 4500 and 5500. It will easily hit 6000 and the prop seems to cavitate. The current prop is 11.75 diameter and 17 pitch. At WOT the boat does 22-24 mph using GPS. It also seems to run bow high while on plane. I looked at the engine trim tube and it used to be one hole closer to the transom as evidenced by the paint wear at that hole. So it has been trimmed out one hole from where it was. It sounds to me after reading many posts here that I could go from the 17 pitch to a 19 pitch to lower the WOT rpm. The michigan wheel prop selector recommended a 12.25 diameter prop with 15 pitch which sounds equilvilent to the current prop.
I'm thinking I should first try the engine trimmed back closer to the transom and try it again before investing in another prop. The cavitation plate is level with the lowest point of the keel which ends up being the bottom of the transom. Any advice or guidance would be appreciated.
