Re: problem with 1996 mercury
Carb cleaner is a waste of money...you need to take the carbs down replace the few gaskets and clean the bowls and blow out the jets...Secondly every boat should have a water separator before the motor...Ethanol plays hell with the fuel system...google it....rebuild the fuel pump every couple of years as the kit is cheap and the diaphrams don't last like they used to. The 115 is a strange animal as it has 4 carbs but only idles on two and has an accelerator pump to help transition to the other two carbs..They are know to idle lousy..still a good motor but just has quirks...
Thanks for the info.... I found a fuel/water separator filter to put on... just need to figure out a good place to mount it where it's both out of sight but also easy to get to in order to change the canister when needed - and still have good fuel flow... not an easy thing on my pontoon where the back left compartment is the 24 gal fuel tank. What size would you recommend? I've seen them from 18 to 56 microns and was thinking of going with a 24 or 28 - filter what's needed without restricting fuel flow and choke off my motor...
I'll try to find both the fuel pump rebuild kit and a carb gasket/rebuild kit.... as well as any and all documentation I can find on how to do them both.... to me that's a huge project since I've never done anything like either of those before... replacing the starter, plugs, and plug wires was challenging enough.... Any pointers for doing any of these? I've never done anything like this before and feel like I'm prepping to perform brain surgery where my actions could kill.... I'm afraid to mess it up but can't afford for anyone else to do it...
So for the weekend I have to:
1) Change the Fuel Filter
2) Install a Fuel/water separator
3) Rebuild the fuel pump
4) Tear down, clean, and regasket the carburetors
wow. color me afraid... very afraid
