Fishermark
- Oct 19, 2003
- 5,617
Went boating over the weekend and noticed that the shifter was "stiff" going into forward gear and throttling up. Didn't give it too much thought... fingured I would look at when I go back home. As I approached the ramp, I suddenly could not go into forward gear. The shifter handle would go into neutral and reverse with no problem, but would not physically go into forward gear. The handle would not move past neutral.
This is on a 1990 Volvo SP-A outdrive.
This morning I had the chance to do a little more investigating. The shifter works fine with the cable disconnected. The cable works fine when unhooked from the outdrive.
The outdrive shifts fine into and out of gear - no problem at all.
The shift plate itself however, will not move into a "forward gear position." Here's a video:
Question: Where does that rod go, and why does it stop moving?
