Primer bulb doesn't soften...ever
I have a '94 sport jet 90. These are notoriously hard to start, but the solution is to put a primer bulb in to prime the engine which it has. Here's the issue, the primer bulb stays rock hard and never softens up for the next start, which means I have to manually spray some fuel into the carbs to get it running. Once running there's zero issues with anything else.
It's been sitting all winter and I checked it yesterday and it's still hard as a rock.
What can I check out to relive the bulb pressure?
are you using the choke when you start it cold?
Yes I am using the choke for cold starts. I bought the boat last August and the bulb has been hard since before I bought it, and I've always choked it.
Fuel primer bulbs go soft when any outboard type powerhead is running.--------So something is wrong here !
I understand there's a check valve in the bulb. The arrows on the bulb point towards the fuel tank, not the engine. Is it in backwards?
the arrows point in the direction you want fuel to flow
gm280
Sounds like you found your problem. The primer bulb is in backwards. Simply change it around and happy boating .
ajgraz
Wouldn't it be nice if all problems were that easy to diagnose and fix?
