oldrudedude
- Jul 3, 2008
- 480
I have a 73 Johnson 100hp. A PO must have left it in the water, because the original paint on the LU and mid section has blistered off up to the water line. The metal underneath has surface corrosion but no noticable pitting.
I would like to prep and paint it but am not sure what paint to use. I am not concerned about original color. I am more concerned about protecting the underlying metal from further corrosion, so need something that will bond well to the metal. I plan to sand the oxidation down to clean metal. Can I use an automotive engine enamel spray can paint with a zinc oxide primer? Or what? any suggestions?
