pre alpha lower unit
KJM
i think the gears in my lower unit are shot, she skips in reverse badly now and even sometimes in forward, also often cuts out when i engage in forward. anyway the drive is a 1978 pre alpha . i think its a MR but not sure. i have ordered a old pre alpha lower unit on ebay from a different motor set up and am hoping it will still fit mine. does the engine size matter for lower unit? i understand the gear ratio is changed in the upper unit?
KJM
so what would happen if the gear ratio was different? will the lower physically fit the upper?
alldodge
If the two are the same ventage then they will fit together, just the ratio may be different. Maybe Bt Doctur can advise more
