Becauseican
- Jun 15, 2010
- 54
My power trim works good when i fist use it after it sat awhile.then its like it gets hot and the motor will stop..if keep holding switch it will jump a few times here and there and then nothing..i let it cool off and it works fine for a few seconds..then samething. the wires were already cut next to trim motor so i seperated them and went straight to batter to see if its a switch problem. no luck..i'm wondering if there is a relay inside the motor.its a 1 cylinder trim motor with 3 wires..also..iwould wrong oil make the motor stop? i would think not...goes on a 1985 40hp johnson.serial number J40ELCO..any help would be greatly apreciated.
