dozerII
- Oct 25, 2009
- 6,527
2008 Mercruiser 43. 1A316906 I replaced the coupler in this boat last fall, had found all the motor mount bolts were loose and the motor was shifting left to right close to half an inch. I ordered a coupler from Iboats a Sierra replacement. Installation went great and alignment was the smoothest I have done. The boat was used fairly hard for approximatley 50 hours this summer. On the last outing at about 40 mph the coupler went again. I'm kinda at a lose as to what is causing this? The fellow that owns the boat can't give me an accurate wot or idle rpm, he says he can get 5200 at WOT and I asked at idle and he said 1800?? I told him 1800 would explode the lower if he could get it to go in!! He is running a stainless five bladed prop that look real aggressive, I can get the details if it it is required. The gimbal bearing is very smooth but is very easy to swivel in the carrier, not sure if that is important?
Any help would be greatly appreciated.
