DonoGrosso
- Jun 27, 2011
- 40
Re: Permission to board, please
I may have bought more project than I want! At least I only paid $1800 for it (which seemed reasonable for a running boat compared to the local market).
I'm guessing the coupler is not an easy fella to get off an on? I am very worried that you're right. I haven't taken the exhaust components off yet, as recommended, but there is no externally visible damage to any exhaust component under the hood. No holes, no burnt rubber, no smoke stains ...
Please tell me I don't have to pull the motor to change the coupler :facepalm:
Assume the coupler is shot, does that explain my issues? (smoke + water + no power). It's easy to see the coupler causing the smoke + no power. Would it cause me to take on water? Or do I have a very unfortunate coincidence?
I am wondering if someone crammed a re-build in there to make it look ok and didn't really do it right ... ? Or didn't align the darn thing the first time -- would that tear up a relatively new coupler? I was looking at it closely last night and the motor mounts and mounting surfaces look new, like it was very recently installed.
Did I miss something? I read thru this rather quickly, I didnt see any mention of an engine coupler failure. The coupler thats bolted to the flywheel that the drive shaft slides into. Burning rubber, has RPMs but no power. If the coupler went bad [spun]the impellar is no longer turning, which would bring on the overheat causing other probs. The wet gimble may just be another coincidental problem. I would put my hand back there and see if there is melted rubber and nastiness around the coupler. Sounds highley possible to me.
edit...........
VANDENTER musta been posting while I was typing ................
