overheating problem 6.2 MPI with Bravo 3 outdrive w raw water pump
39rolls
Engine runs about 175 below 3000 RPM then climbs above 200 after 3000 RPM, go back below 3000 and temp. falls to about 175. Seawater pump has had a new impellar installed and still did not fix problem. However when you look in the sea strainer it appears to be only about half full with engine running. Shouldn't it be full? Could trouble be between water pick up and sea strainer? This problem has gradually manfested it self over a long period of time, Gradually getting worse and worse.
tpenfield
Re: overheating problem 6.2 MPI with Bravo 3 outdrive w raw water pump
It could be sucking air . . . check the intake hose from the transom to the strainer and then onto the sea water pump.
Another place to look is in the outdrive where the inlet hose runs from the outdrive to the transom assembly.
Pete104
Keeping your raw water pump up to date?:)
TilliamWe
Banned
What about a restriction after the pump? Did the previous impeller fail? If so, did you get ALL the pieces out? One could still be in there, restricting water. (Although it should still be able to suck up the max amount of water)
