I recently bought an '88 winner Tourney 2000 w/ an '87 yamaha 200hp Precision blend(model: 200 ETLH). I have changed the water pump, spark plugs, Lower unit oil, 2 batteries, removed thermostat, and just thisafternoon finished rebuilding the carbs. before i bought the boat I did a compression check. W/ low battery charge all cylinders were 110-120psi. I read somewhere on here over 100, and no more than 10% out was ok, so i bought it.
Anyways after finishing all my prereq chores on it, I decided to fire it up tonight. After only around 2-5 mins of running w/ ears on( it was pissing), the overheating buzzer went off. I immediately shut it off to let it cool down. The right side head wasn't even warm, but the left side head was smoking hot. After it cooled off, i tried it again w/ the same result. Pretty sure it's not an oil problem, cause i went ahead and mixed the gas until i could run it long enough to see if oil injector was working.
Something deep down in my gut tells me this is a huge problem >.< I hope after all this work and money it's not a bad motor. Help PLS!
Thanks in advance for any input!
-Andy
-Andy
