Its me again. I'm try to get my Alpha 1 Gen II outdrive on and I can not get it to go the last inch. Everything is lined up, I know the splines are connected because they are 3 inches long and I only need the last one inch. I suspect I still have an aligment issue but I'm wondering if there is anything else I could check before starting that. I had an extensive post about alignment last weekend http://forums.iboats.com/cgi-bin/ubb/ultimatebb.cgi?ubb=get_topic;f=24;t=016735 <br />When I slide the alignment bar in there is still a slight resistance (I can almost do it with one hand but not quite). It is definetly going all the way in. I need a slight tug to get it to come out. Is that enough to cause me the outdrive install problem? Any advice is greatly apprecaited. Thanks
