<br />To answer your questions:<br /><br /> Would you know if these tolerances are critical, or would a 13 mm hole be fine? <br /><br />The tolerances for the hole are not that close. (A .512 of an inch or 13 mm hole would be fine)<br /><br /> <br /> Are there any other precautions necessary, like painting the inside of the holes to avoid galvanic corrosion, or anything like that? <br /><br />Most people dont bother with painting the hole, but it certainly wouldnt hurt. I tell people to cover the top of the hole with a piece of tape, and spray upward at the bottom of the cav. plate. The tape helps with the overspray and nobody cares if the bottom of the cav. plate gets extra paint on it.<br /><br />Hope this answers your questions,<br /><br />Paul Kermis<br />Pres. Simrek Corp<br />
