Happy Holidays to all. My boat is a 1995 Bayliner Capri, 3.0 Alpha-One gen2. Just finished installing the engine and was reading through the manual for replacing the water pump in the outdrive and the installation process. The manual says that the seal inside the bellhousing bore need to be glued in or water till leak into the boat after outdrive installation?? Glued??? Also how important is replacing the 3 orings on the U-Joint shaft, it appears the seals in my kit arn't the right size (not fat enough).. Water passage seal looks correct.
