Does anyone know what the correct torque is when istalling the outdrive? It's an Alpha 1 Gen 1
S smithrock Petty Officer 1st Class Joined Jun 11, 2007 Messages 399 Aug 16, 2009 #1 Does anyone know what the correct torque is when istalling the outdrive? It's an Alpha 1 Gen 1
Don S Honorary Moderator Emeritus Joined Aug 31, 2004 Messages 62,321 Aug 16, 2009 #2 Re: Outdrive nut torque? ASSUMING you are referring to the 6 nuts holding the drive to the bellhousing, 50 Ft. Lbs. Can I assume you didn't download the manual?
S smithrock Petty Officer 1st Class Joined Jun 11, 2007 Messages 399 Aug 16, 2009 #3 Re: Outdrive nut torque? Don S said: ASSUMING you are referring to the 6 nuts holding the drive to the bellhousing, 50 Ft. Lbs. Can I assume you didn't download the manual? Click to expand... I have a hard copy of the manual. It's in my truck - truck isn't here! thanks for the info though!
