Johnson 90hp 4-cyl. j90plee p or R (can't read last letter)
I have no spark on all cylinders and everything is diconected at the engine so I am bypassing everything from the helm. I am on the step where you test the yellow/red wire for voltage while cranking and have a couple of questions.
First off, is this the wire at the top of the coils on the port side of the power pack? There are two plugs up there each with a bunch of wire and that one on the port side is the only one I could find.
Does it have to be plugged into the power pack to get 12v?
If this is the right wire I can't seem to get 12v there no matter what I do. I tried to put 12v to it while while cranking to see if spark would come back but it didn't and the engine started to raise up which I thought was strange.
Any ideas, maybe a wire diagram?
