oxbeast1210
- May 14, 2010
- 309
TE150SLCEM 1989 evinrude xp tracker 150hp
Ok so my issue is that my outboard would die when i moved the throttle forward unless i apply the choke at the key switch after its choked it runs fine
Must people suggested that i get the carbs rebuilt but first to make sure the link and sync is right according to the manual . so these are my questions
1: the air silencer cover was missing the bottom screw and its gasket what kind of issues would that cause?
2: i did the link and sync according to the manual but i cant get the butterflies on the carbs to open 90 degrees before i started the link and sync the butterflies were at about 30 degrees at wide open throttle could this have been what was causing my issue of the motor dying at anything more then 1/4 throttle?
3: lastly even after adjusting the stuff according to the book i cant quite get 90 degrees on my butterflies the cable when at full throttle doesn't pusk the throttle cam enough to open the butterflies to 90 i adjusted the plastic wheel on the cable but it will not go further in that direction
attached are the picture of my butterflies at wot do you think this is close enough to 90 degrees?
thanks everyone
thanks everyone
