rtoomey641
- Jul 8, 2016
- 93
Hi 5.7GSIPWTR Had a misfire checked heads had 3 bad valves had them replaced as well as seals and guides and machined both heads. New plugs,wires,cap, and rotor. Engine not running right plugs look ok except 6 is carbon fouled. Compression 170 on all cylinders. Leakdown on 6 is 35% and on 1 is 30% used a tester from Harbor freight had 12psi going in the numbers were in the green area still. What should I look at next?
