imported_scott_m
- Oct 24, 2004
- 139
Not sure if this is the right forum. I spend a lot of time over in the Mercury section. Anyway, I've got a 1988 vintage gas powered Onan 6.5KW generator. This gen is fresh water cooled. The unit has pretty much been rock solid reliable over the past 7-8 years I've owned it. It's always used a good bit of oil (leaks and burns some), but my understanding is this is pretty normal. This unit also does not have an oil filter, so it basically changes it's own oil every 50 hours or so. Other than occasional oil changes and a new set of plugs (yikes) two year back, it has been great. Recently, the generator has started backfiring under load. At first it seemed like it would only pop and then stumble a little bit as the load was coming on line (for example when the AC compressor would start up), but this past weekend it was just popping and stumbling all over the place....it never does die, but it just sounds terrible. I'm pretty sharp mechanically, but don't know much about these generators. I'm thinking maybe a carb rebuild?<br /><br />Sorry for the long post and if this is in the wrong place, please feel free to move it. Thanks in advance!
