struyffamily
- Mar 9, 2002
- 4
I have a 2 cyl 2 stroke 15HP inboard OMC engine (OMC Sail Drive Zephyr)with ignition problems. It's on our O'Day 25 (1978) and the model is 15S10S.<br /><br />I measure merely 80V AC output doing the Charge Coil Output test(should be > 230V).<br />I replaced with a new charge coil, but... result is still the same...!<br />The charge coil resistance is 470 Ohm as per specs. Sensor coil is OK according to all three tests, 42 Ohms, no leak to ground,<br />0.55V AC output.<br /><br />What could the problem be? Does someone know this model? Is it the power pack?<br /><br />Thanks
