Hi all,
I have a 1990 Sunbird Corsica 19.5' with an OMC 5.0L Cobra, with Cobra outdrive. This engine has been running great; sounds good at home, idles well, sounds good at speed. Just had timing/carb adjusted at local shop. Runs sweet. However, yesterday on the lake, problems arose. When idling, it is fine. When I get on it (to get up on plane), it would start to go, then shut off as if I turned off the key. It would then start right back up. After a while, I would be able to get it going. However, I could hear it hesitating, then hitting WOT, then hesitating some more. It seems to me as if its not getting fuel....I may want to check the fuel filters, as I have read this engine has several. It seems to me sometihng is clogging the filters, then falling away, allowing me to get on plane then. Before I go ripping in to anything, I figured I would see if anyone out there has some tips/ideas. Caught me off guard as it ran flawless two days prior...very sudden onset.
Engine running at good temp (1/3 of the way up the temp gauge)
Idling at 550 rpm
When running smooth, WOT is 4200 rpm.
When I engage the neutral switch and rev engine, it revs fine. Just seems to be happening under load.
Thanks all!
Idling at 550 rpm
Thanks all!
