JIM MCCARTHY
- Sep 27, 2006
- 57
As I read my manual, the tilt clutch housing is supposed to hold 15-18 lbs pressure. Mine doesn't, and I can't seem to find any leaks. I replaced the o ring on the cover as well as the gasket, but haven't gone any further yet. Soapy water reveals no leaks at the clutch cover nor the shaft seals. Likewise, no leak is evident at the worm gear shaft retainer. Are there seals at the motor end of the worm gear that I should be looking at? I don't see any seals indicated in my manual.
