Re: OMC 185 V8- Thermostat
if you are not using the boat in salt water, use a 180? thermostat. This is also assuming that your motor is carburated, not FI'd.
Somewhere I saw a graph of engine wear for cooler running engines. This includes 160? stats. Cold engines run tighter and create more wear. Also, in addition to reducing cylinder wear, 180-195 is optimum combustion chamber temperatures.
160? thermostats were only ever a compromise to try to keep salt from plating out inside the block. No salt-Too cold!!!
Also, as mentioned above, a thermostat also keeps the engine from being alternately shocked by cold water. The continuous expansion and contraction of the block and heads are not a good thing.
