Captain Fishfry
- Apr 24, 2012
- 18
Good afternoon everyone...
I could use a bit of advice for a boat restoration project I've been working on. This is my 1st boat, so do your best to bear with me. My problem is that from what I have read, and my manual states that my engine should be operating in the 4800-5500 rpm range. Right now, I'm barely at 4000, and that is with myself, and a buddy. By myself, 4200. Here are some specs:
1981 Bass Tracker III 16'
40hp Mercury 2-Stroke, 2 cyl (#6053214)
10 1/4 x 13 prop, aluminum (mercury)
When I got the boat, it did not run well, which is to say, it didn't at all. This is what I've done so far:
New gaskets throughout, (carb, header, fuel pump, exhaust manifold etc. etc.)
Complete carb rebuild, I didn't just clean it, I actually replaced every part in it. (jets, needle and seat, float, everything. Fuel screw at 2 turns out)
New spark plugs
Complete fuel pump rebuild
replaced in-line filter under the hood
new 7.5 gallon fuel tank, with new hoses and primer bulb
new throttle and shift cables, properly adjusted per my manual
new water pump and impeller
compression test at 114 on both cylinders, although, one cylinder seems to take a few extra strokes to get there (???)
The engine fires right up, and it has a nice smooth operation when on the water, but 15 years of riding dirt bikes tells me that it's lugging a bit. I don't know much about the electronics or timing of the thing, but I do know that in order to get into the manuals rpm range I would need to back down to at LEAST a 9 pitch prop, more than likely an 8. That seems a bit drastic to me, what do you guys think? I would like to know if there is something I should look at before I start throwing money at props...
Thank you for any and all help
New spark plugs
