Re: Old 6hp johnson
Sounds exactly like the problem I was having with my 67 3hp Evinrude.I rebuilt the carb and it ran perfect.Then I ran the carb dry and the next time I tried to start it,I had hell.Had a hard time getting it to start and when I did,it would only run with the choke on.This is what I found.At the bottom of the fuel bowl near the center is a high speed orifice.Mine has a brass orifice plug that requires a special tool to remove,so in rebuilding,I could never clean it well.I dug around in my tackle box and found some .025 dia. stainless steel solid wire leader and was able to work it through the tiny orifice.After working it back and forth several times,I could feel it cleaning the crud out that was built up inside of it.Put the plug back in the fuel bowl,turned on the gas,pulled the choke,pulled the rope and she fired right up!!!!!!!!! It now starts with only having to pull the rope a little over half way out and on the first pull everytime just like a new one.So it was that one tiny little orifice was giving me all that hell.I took it out for a test run,ran perfect for about a mile and quit.I paddled over to an island,removed the plug at the bottom of the carb.,ran the wire back through again and she fired right up and ran perfect for the rest of my outing.So that little wire,a paddle and a few tools is something I will not leave home without.
