aarons 470
- Aug 29, 2012
- 351
Looking for a place to run the wire from the “ i “ tab on my oil pressure switch for the electric fuel pump.
Is it ok to use the positive side of coil, or does that rob to much power from ignition?
Will be Using Petronix igniter ignition module with matched coil, if that makes a difference.
If not coil, where should I run the wire for ignition power?
Thanks
Thanks
