Have a 1999, 9.9 Mariner Outboard, and when i set it on the stand after using it, i noticed that there was a lot of what looked like gear oil in the hub of the prop. When i pulled the drain plugs for the lower unit I noticed that there was not much oil left, but there was no water in there either. I was wondering if the seal around the prop shaft is wore, or what happened. Any help would be greatly appreciated....<br /><br />Belchy
