Re: oil consumtion on a rebuit 5.7
If I remember correctly, a windage tray is only useful above 5000rpm, or 6000rpm? to keep oil in the pan, you really don't need one. But, if it's only smoking cold, it might be the valve guide seals, on a small block chevy, they are only small o-rings from the factory on cars, hardly worth putting on, they disintegrate in no time! Boats, and Pontiac motors, use an umbrella style seal, that fit on the Chevy motors, there probably is an OMC, and a Mercruiser part # for them but I don't know what it is? You can buy them over the counter at a good auto supply store, they are made by Fel pro also, but I don't know the part # for them either, just ask for Pontiac V8 stock valve guide seals. If this is your problem?, that is the cure! Your mechanic should have put the right ones on, then it might be something else.
