so the level of the top side of the fiberglass hull around stringers and the level of the bilge sump are at two different levels (bilge higher than top of fiberglass under deck). noticed when i got a bit of rain in there and it was not draining out of bilge drain hole, not even going into bilge sump.
thinking of some sort of self-leveling material on top side of fiberglass under where deck will be to bring this up to the same level as bilge sump so any water that gets under deck around stringers will be able to drain into bilge sump then out of bilge drain hole. thoughts, would hate to dump resin in there to level things out as that would be a large amount of resin
