Haut Medoc
- Jun 29, 2004
- 10,645
Hi All....
It's been a long time.
Here goes:
I recently purchased a 1979 SeaRay SRV 30, with twin GM 350's (255HP).
Ran great on trial.
When I did some PM, like I do on everything I own, on the port side engine, (standard rotation), I could not see the timing mark when I put the timing light on it.
It sounds good & with a mirror, I was able to see the mark with a mirror on the nearly 6 o' clock position.
This would normally tell me that the wires are in the wrong position & that some other cylinder should show on the timing tab as I moved the tester connection from ignition wire to ignition wire, I thought one should be in the ball park, but no.
The closest I could get was to see the #2 past the timing mark, (ATDC) or at # 7 (BTDC) and basically right in the middle of both with either left me trying to retard, which made it run too slow & want to die or too fast which made it race.
The distributer is a billet type Pertronix.
I am much more familiar with Ford, but if I recall a GM dist. only goes in one of two ways on or 180 out.
I just can't figure out why I am basically 22 degrees off either way, right in the middle of either 2 or 7 lining up.
I'm missing something here & I don't know what.
The engine sounds good, but I really don't want to cruise it until I am satisfied it is timed correctly according to the mark & tab.
I tried bringing it to TDC and just can't get it to run using what would be normal procedure.
Brand new plugs were black after short use.
Any help appreciated....... Thanks!
Here goes:
Ran great on trial.
