TrueNorthist
- May 16, 2012
- 229
1985 J70ELCOS, aka a 70hp Johnson. After sitting for a month or so the engine clearly has dropped a cylinder and idles very rough. I replaced the spark plugs and performed some tests and eventually went for a quick shake-down run at a small but extremely busy lake which revealed a normal running engine. It hesitated a bit at first and was slow to climb out of the hole, but like throwing a switch she just snapped out of it and ran fine for an hour under all conditions.
Fast forward a week or so and at a different lake the engine again dropped a cylinder right away (I am fairly sure it is #3, the plug has a different fouling pattern than the others, with only half the radius of the plug fouled) This time I pulled the carbs and cleaned, blew out and synced them while inspecting the entire fuel system. I replaced a few borderline hoses but the carbs were fairly clean. I disconnected and cleaned and reinstalled all the ignition wiring and ran static tests on the coils which check out to spec. Running on the muffs I can easily jump a 1/2 inch gap with a crisp blue spark on all 3. Compression is 127, 124 and 123 from 1 through 3 and it is now idling very nicely, again on the muffs.
My question is: can the power-pack be the cause of this sometimes dead, sometime not cylinder? I cleaned all the connectors at the bus but do not yet have a DVA tester made up to check output.
