jrboat2011
- Mar 16, 2011
- 36
How is the best way to remove the nut that holds flywheel on, flywheel turns when I try to loosen nut.
Do it the right way, strap wrench or flywheel holder tool.
OR
Use an impact wrench. It will zip it off there in second. But you still need to hold it to reinstall the nut.
OR
1. Obtain a big screwdriver.
2. Stick it between the flywheel teeth and starter pinion teeth.
3. Remove nut.
You must use a torque wrench to reinstall the nut to correct spec. Don't even think of cheating on this.
I fab'd a holder out of a piece of plywood. see pics. Provides enough length to counter the nut removal torque. Works even better with the block on a bench on its side. However I just did a stator today with motor on the boat, and It was just as easy to get a flat screwdriver in the teeth and against the solid bracket of the advance indicator (just be careful), and the nut came right off.
Popping the flywheel is another matter Search the forum, lots of tips.
View attachment 206383View attachment 206384View attachment 206385
I must be fortunate in this area. i've never had to go to any of these measures. if i can't break it loose by holding the flywheel by hand the 1/4 drive cordless impact gets it every time
