My 2003, 350 Mag I/O Mercruiser engine is supposed to hold approximatly 5.25 quarts of oil. I hooked up the water hose, started and allowed to get up to operating temperature, 170 degrees. I already had the Quick Oil drain hose out of the tansom hole, and laying on top of the oil pan. After getting to operating temperature, I killed the engine, and pulled the plug out of the end of the quick oil drain hose! I jacked the boat up in the front, "on the trailer" and allowed it to drain. After much draining, I was told to take a sharp punch and tap a hole in the top of the Oil filter, to vent, and allow it to drain its contents also, through the motor. I then got rags, and removed the oil filter, no problem so far. I also allowed it to drain all that day, and had even jacked up on each side, and lowered the front. I did not know the location of the Oil drain port that the quick Oil drain system is hooked too, so time was allowed in each of these position over a few days, of draining. I also changed the fuel filter. Then I replaced the plug in the hose, and put on new oil filter. I then got one gallon of recomended Oil and poured into the engine. Let that settle and checked the oil. Using the dipstick as a guage I'm guessing I'm a quart overfull. Now, I have not started the engine yet, and I know the Oil filter will suck up about a pint of this. So to double check myself, I took the drained oil from the catch pan and poured it back into the gallon jug container that my new oil came in. I'm guessing over 3 quarts, not quite 4. <br /> <br />Does not sound like a good oil change to me! Especially if the motor is supposed to hold approx. 5.25. I'm very glad I decided to change it at 85 hours now. I have plans to change it again at 100 hours, and may change it every 50 hours from then on. I would appreciate any suggestions, tips, to check or do to get more oil out in future oil changes. <br /> <br />I have posted on other sites, and one reply that could be a possibility is that the oil drain tube, might be positioned or pushed too far into the oil pan, and not allowing the bottom contents to drain. This being the case, this would be a warranty problem, but I'd hesistate to pull a good running engine over this. I commented that I might report the problem to my Warranty Service record, to get it on the books, and just try another oil change at 100 hours, and see if I get better results, and if not, buy the pump "which I think is stupid with having the quick oil drain system", to get the remaining contents out. Then with the problem reported on the Warranty Service record, the first time the engine has to be pulled, the oil drain repair, at least would be warrantied. <br /> <br />Can anyone see another angle to approach this problem? HINTS, COMMENTS, SUGGESTIONS, welcomed.
