Hello. I took my Suzuki DT75 out on the water the other day, the motor was running perfectly. I ran out of gas in one tank and then the problems began, I switched tanks, the motor started up and ran awful, no power at all, I took the motor home and flushed the salt water out, the motor started strong and still ran a little ragged. I took it out again yesterday, the motor started strong and still ran a little ragged once again, but I thought it would clear itself up once i got out of the channel, the problem got much worse however. The motor kept making an odd "chirping" sound, I assumed it was backfire? It would run for 10 seconds at the most and stall, if I was able to get the motor running long enough to open it up in neutral, it would run, but on 2 cylinders. I eventually got towed in from my uncle who owns a sailboat. I checked fuel lines, primer bulb, everything was fine. The plugs are new, the gas tanks we're just cleaned out and the fuel filter is new. Can anyone help? I really would like to solve this today and get out and see some fireworks.
