I have a 2006 Yamaha 150Hp four stroke that will only start on my battery position one. When I move the switch to position two I get a clicking noise and the battery voltage drops to under 10 volts (like a dead short). If I exchange the batteries to the opposite positions the same thing happens. I have taken the switch out and took it apart and it looks brand new, did a continuity check and all switch positions check out. I disconnected the battery from all connections and used jumper cables to connect it to the input port of the switch with the same results. I then put the jumper cable directly onto the output terminal and it reacted the same way (meanwhile the position one of the switch will always start the engine). Any ideas?
