I have a1990 Larson with a 5.0 Merc that didn't hit the water last year, and the year before sat in the water as a floating dock as as soon as I dropped it in the water I realized the gimbal bearing needed replacing....anyway, I am not getting fuel from the tank to the carb. I changed the fuel pump a couple of years ago and it has about 1 hour on it...this is also true for the rebuilt carb. I changed the anti-siphon valve at the top of the gas tank today and still...no fuel to the carb. I changed the fuel filter and filled the filter with fuel before installing....I even filled the line from the tank to the filter with gas before re-installing the line. Today I cracked the fitting on the fuel pump line that goes to the carb and had my son turn the engine over...it is not spurting fuel from the fitting. If I fill the bowl in the carb it will run for a couple of seconds until the bowl is empty. Usually I will moisten the gasket on the fuel filter with motor oil before installing, but I didn't do that this time...don't know if that could be it. Also this has an after market fuel tank from mohler and the fitting (to which the anti-siphon valve is affixed) and tube will pop from the top of the tank when medium upward pressure is applied.
Thanks in advance for reading!
