Home Cookin'
- May 26, 2009
- 9,715
Re: no brake or turn signal
This happened to me; I relate it not as something going on with yours but an example of what can happen:
my trailer lights would cancel out if I hit the brakes while the headlights were on. Chevy Tahoe. Turns out that at the truck wire harness there was an extra white wire which everyone assumed was a ground--and grounded it. But it was an auxilary brake light wire (like for the center brake light on top of the rear windshield) and was powered when you hit the brakes, causing some kind of short/loop/whatever. And that was hooked up by a chevy dealer.
So you may be looking at reworking the vehicle wiring. In fact, next thing I'd do is hook that trailer to a friend's car and see what happens. Then hook his to yours. really, that's the first thing we all should do with these problems.
other things that can go wrong:
Bad connections at splices (esp. at the running lights) inside the frame
A worn spot on a wire inside the frame grounding out
bad ground connections between the parts (similar to the tilt trailer issue mentioned above--good point
Something crossed up so your colors of the wires aren't right.
Get 20' of wire, make a jumper and try running that from each light back to the plug, to identify problems in the existing wire.
Dedicated ground wires are the way to go.
