I love this engine...
However, I have cleaned the carb three times, new fuel twice, new fuel filter, new plugs and same problem. I think I'm down to the fuel diaphram but not sure....
The engine starts ok- not as good as it used to before all this happened. But, now everytime I run it for about 20 15 minutes it dies. Can be running along at 1/2 throttle and then nothing. I can usually start it but it then will only run at a high rpm. If I pull the choke out it seems to run better after it dies but still this has got to be fuel related right? Not sure where to turn on this. I clean the carb again- soak for 3 hrs or overnight in carb cleaner and then blow out w. air compressor. I am looking for suggestions on this one though. BTW, what is the compression supposed to be on these engines- i could check that but dont necessarily think that it is the problem.
Many thanks
dave
Many thanks
dave
